Arvixe添加站点出现错误解决方法
posted on June 27th, 2012 BY user1
最近,在论坛有看到Arvixe用户添加站点(WebSite)的时候,出现不能添加的情况,显示以下错误:
Error creating Web site.
System.Web.Services.Protocols.SoapException: Server was unable to process request. —>
System.NullReferenceException: Object reference not set to an instance of an object. at WebsitePanel.EnterpriseServer.WebServerController.AddWebSite(Int32 packageId, Int32 domainId, Int32 packageAddressId, Boolean addInstantAlias)
— End of inner exception stack trace —
笔者也联系了Arvixe官方在线客服,给予的回答是: And the site is already created in IIS and that caused the issue,Removing site and application pools from server so that you can add it in the control panel.
所以,我们要求官方客服帮助我们从服务器上删除the site and application pools,这样,我们的Arvixe主机就可以再次添加站点了。
Note:以上这是Arvixe官方给予回答,问题能否解决,笔者并没有测试,如果大家出现此类问题,不妨联系Arvixe官方客服看看是否可以解决。
TAG:
Filed Under:Arvixe使用
